Noise
Noise
When my stereo on my bike is muted I can here a white noise in the speakers almost like a real soft hiss, is this normal? It's also faintly hearable on volume level 1. It doesn't seem to get louder when the volume gets turned up instead it seems as if the music covers up the sound. If the head unit is muted it must be a sound created from the amp? I'm running a ss4.520 and bt speakers.
Hmmmm...... well that sucks! I have both front and rear gains set right around the 12 o'clock position. From your experience does this seem higher than normal? I had been running them at the 11 o'clock position but since I had it opened back up to install my rear speakers I figured I would run them alittle higher to avoid running the HK head unit at such a high volume. I was hoping this would help me with distortion until I can upgrade the hu
