Amps for 7.1 ????
Old 06-22-2014, 12:28 PM
rider718's Avatar
rider718
rider718 is offline
Is there a video showing how to install this amp on a bike? The printed instructions are not clear at all.
Old 06-22-2014, 12:41 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
which amp?
Old 06-22-2014, 12:42 PM
Pioneer74's Avatar
Pioneer74
Pioneer74 is offline
Go to Youtube and search for "Bagger Nation Amp Install".
Should come up with multiple videos on an aftermarket install.
Old 06-22-2014, 04:29 PM
rider718's Avatar
rider718
rider718 is offline
Originally Posted by UltraNutZ
which amp?
The Rockford Fosgate PBR300x2 on a 2012 Ultra Classic
Old 06-22-2014, 04:34 PM
UltraNutZ's Avatar
UltraNutZ
go to this link.
https://www.hdforums.com/forum/audio...tructions.html
use the first one. it's for a 2007 but the wiring is exactly the same. just substitute your speakers in place of the crossovers and polk speakers.
Old 06-22-2014, 04:44 PM
rider718's Avatar
rider718
rider718 is offline
I guess what I actually need is to know what wires to connect where and so forth. I have the amp installed and power / ground wires ran but the actual wiring is what I need help with. The written instructions I have found are confusing and may as well be written in Arabic.
Old 06-22-2014, 04:51 PM
UltraNutZ's Avatar
UltraNutZ
cut the RCA jacks off the amp input harness.
that leaves you a grey and grey/black wire and a white and white/black wire as your inputs
the speaker wires that are currently plugged into your stock speakers are
right (sitting on bike)
grey/red stock wire goes to the grey wire on the amp
black/green stock wire goes to the grey/black wire on the amp
left (sitting on bike)
white/brown stock wire goes to white wire on amp
white/green stock wire goes to the white/black wire on the amp
the output harness on the amp has the same color wires
grey/black goes to your new right speaker (sitting on bike) - terminal
grey goes to your new right speaker + terminal
white/black goes to your new left speaker (sitting on bike) - terminal
white goes to your new left speaker + terminal
Old 08-02-2014, 11:09 AM
rider718's Avatar
rider718
rider718 is offline
Ultranutz,
Thanks for the reply. Satchmo and I finished this installation today (took several weeks to get back together) and followed your wiring instructions and it worked perfectly.
When we fired it up, it worked great, sounded great, and was just what he wanted!
Thanks again.
Rider718
drew1879@gmail.com
Audio Systems
05-12-2016 09:37 AM
b_townchops
Audio Systems
03-19-2014 07:14 PM
blackflhx
11-13-2012 09:31 PM
crawlerman
Audio Systems
28
04-08-2012 09:34 PM
c50plus
10-03-2011 03:59 PM
Quick Reply: Amps for 7.1 ????
