Help with 2007 Ultra audio upgrade
He said he bought the PBR300x2. There's only one gain setting with that amp. I'm assuming he'll run the front and rear speakers in parallel since it's a 2 channel amp.
[QUOTE=hivoltg;12738964]Do I run the kicker's with just the factory radio pushing them?
I think you can drive them with the HK head unit; or as an alternative you could run all four speakers in parallel from the PBR300X2; but since it's a 2 channel amp you'll only have left/right channels. If you're going to drive them from the stock HU you'll want speakers that are efficient. Personally, I'd choose a 2 ohm vs. 4 ohm speaker if you're driving it from the HK head unit.
I've read in other posts on the forum that the 62.11i's will fit in the tourpak pods as they are relatively shallow depth. I believe you will have to drill new holes to mount them in the pods.
Ok, apparently I have confused some folks here.
I plan to run the infinity speakers in the fairing, with the amp pushing them.
I plan to run some speakers in the rear pods, just powered by the head unit. However I may buy an amp for them in the future.
Can I run the same infinity speakers in the rear pods? If not, what would be my best option?
http://www.crutchfield.com/p_575T400...ad.html?tp=115
