Help with 2007 Ultra audio upgrade
http://www.sonicelectronix.com/item_...FY3m7AodUiwAKQ
Get the infinity 62.11i for the fairing.
Get the Kicker KSC67 for the rear pods.
The Kickers have the solid grill your looking for and fit right in the rear pods like a glove. All you have to do is drill 4 holes for the screws. The amp is a four channel so each speaker has thier own channel.
Both speakers are insanely loud and clear @ 75 MPH.
Get this amp:
I saw on Amazon where they say the Infinity Kappa 62.11i 6.75" will fit into 6.5" hole..is this correct ??? Then will the Arc Audio 6.5" Speaker Adapter Rings work ?? anothe r question..sry..When purchasing the Rockford Fosgate PBR300X2 thru Amazon..Does this amp come with all the wiring to install on my Ultra ??
THX
THX
The Power Acoustick was installed by a member of the forum just this past week and he stated he did not lose his FM reception. However, it was not the model I suggested. Honestly it's a crapshoot. Who Knows? Just depends on the radio and the specific amp. I'm not convinced the FM issues are prevalent with ALL class D amps.
I really don't want to give up my FM reception
I am ordering the PBR300X2 and looking for instructions to hook it up to my 2010 Ultra Limited. ..I had a Hogtunes years ago but it was plug n play so very simple to hook up. I am just worried about getting it right and then hooking up to my new BT 7.1..I did also order the Rockford Fosgate RF10 power only install kit. . Was this even needed ?? Need some guidance. .THX !!!!
Should I have ordered something besides the Kickers for the rear pods?
