Best way to put an Ipod on a harley
Old 04-20-2014 | 08:32 AM
DustyRG's Avatar
DustyRG
Stage III
Default Best way to put an Ipod on a harley
Have a few ?'s here.I have `12 FLTRU and started checking into different
ways to listen to my ipod.Is the Harley ipod modual worth getting?Seems expensive for getting handlebar control and charging.Does this method sound better?I like the idea of just leaving it in the saddlebag.Should I just use my charging cord and plug it into the aux on the front of the stereo?
Thanks for any input,pro's and con's.
Old 04-21-2014 | 12:31 PM
rb22858's Avatar
rb22858
Honestly in my opinion the HD iPod interface is the best out there for full integration. I have it and swear by it. There are others that sell their own but sub par and I have not heard good things about them. The aux solution is the cheapest but then u have to have to find a way to charge the iPod. If you use your iPod as much as me I say get the interface. good luck.
Old 04-21-2014 | 01:16 PM
ElGigante's Avatar
ElGigante
duct tape it to the dash :-p
if you want to stay stock headunit- get the ipod interface. if you want the best options - replace your stock headunit with a aftermarket that has build in ipod controls
Old 04-21-2014 | 01:23 PM
kryingame's Avatar
kryingame
I have my Ipod on the left handlebar with a RAM mount. Works for me.
Old 04-22-2014 | 05:43 AM
Gooey2's Avatar
Gooey2
Try iron cross better deal
Old 04-22-2014 | 10:29 PM
Sire2Twins's Avatar
Sire2Twins
+1 on the HDPD2 from Iron Cross. A lot less expensive than the Harley branded and works the same. Handlebar controls, charging and out of the elements. Can also see the songs and playlists on the Head Unit. The only negative for me is that you can't easily select a song or artist without scrolling through the whole list alphabetically, but with some creative playlists that problem was solved.
Old 04-23-2014 | 09:35 AM
murph's Avatar
murph
I also have the HDPD2+ and love it. Works great. I made several different play lists. I only have to thumb up to change the play list. Sounds great and works great. Plus, its a lot cheaper than HD's version.
Old 04-23-2014 | 09:53 AM
Manninagh's Avatar
Manninagh
I have a Ram mount for my Iphone when I use it for tunes and satnav when away: phone in waterproof hard case with ports for charger and 3.5 cable to aux in.
Around here I have a ipod shuffle on my clutch mount using a little square of Velcro - battery lasts for days, 3.5 cable into aux in. I can reach the controls with a finger without taking my hands off the bars. Cheap, too!
Old 04-23-2014 | 12:14 PM
28INF's Avatar
28INF
I've reviewed a few products that plug into the headphone jack to make it wireless... not worth it.
Old 04-23-2014 | 12:18 PM
28INF's Avatar
28INF
Best to buy the Bluetooth from Kokkia.... $55
Quick Reply: Best way to put an Ipod on a harley
