Amp and Speakers questions
Ok so I am not sure if this is an error on my part but I just recently installed a PBR300x2 amp and Polk Audio mm651's and from what i can hear so far it seems like i have something messed up cause the sound is horrible right now.
I hooked all this up this past weekend with a new radio (Sony Btx310) and im was only able to get sound to work using the RCA cables which was odd to me because when I wired in the amp I would have thought that would have been the better route but i had no sound so now im just running RCA cables to the amp. So then last night I installed the MM651's and at which point i used the wire input to get those to work. So as it stands now I have the RCAS connected on 1 side and then the imputs connected on the other side and I have really bad sound so far. I played with adjustments and i dont think i am anywhere close to the potential of this set up.
If anyone has any knowledge of this setup or input please let me know.
