Polk mm651s completely destroyed in 800miles
The amp is fine. It's a defect in a certain batch of speakers. It's been discussed on this forum for the last two years.
Well all I can really say is heat became a issue at some point in the process. Either the tweeter came apart and then proceeded to melt down or they melted down and that was the main cause of the failer. Either way if I had it to do over again I would have to say that poly fill probably made this situation worse. After looking at a melted down speaker I would have to say insulating these speakers is a bad idea, I could be wrong. I'm hoping ultranutz will chime in at some point and maybe shed alittle light on what he has seen with these speakers. My next question would be are you folks running the biketronics 7.1 using Polly fill? Also is it common for speakers to produce heat? In my younger days with car stereos I recall amps running hot but never any heat from a speaker that I can recall?
I have a set of 7.1's waiting to be installed. I'm also upgrading from the MM651's. In preparation for the install I asked about having to use polyfill with the 7.1's.
They seem like such beasts why would you need it?
But I was told by Ultranutz to use 3 thin layers in a 15x15" square wrapped around each speaker.
I had read about this and was on the fence between these Polks and the Hawg Wired 6.5". they are very comparable in all ways including price, except the HW speaker has the tweeter bridged instead of mounted through the cone like the Polks. Then with all of the complaints about meltdown's and bad batches that pushed me toward HW.
I think HD's boom speakers also have the tweeter bridged.
Instead of polyfil, I found a set of molded foam specifically for 6.5" speakers off of ebay that I just cut a slit for the speakers wires and that's it
IMO, the polyfill had nothing to do with the Polk's self destructing. People have been wrapping speakers for years with nothing but good results. This is the only speaker that people have had self destruct on them.
Magnets heat up at higher wattage, just like electric motors. That's how they work. Polk has a problem with a cheap assembly process and glue. Obviously it isn't with just one batch as ridedaddy just put his in.
Ridedaddy, I would get yours replaced. Polk has been very good about replacing speakers. Nothing on a mass production line is built the same, maybe your next set will be assembled better.
Good to know, and you are correct my speakers were only purchased about three months ago. But do to the Illinois weather they have been unused until now. Anyway I'm hoping polk will replace them so I can offset some of the cost of the biketronics speakers. I assume the Polk speakers would hold up better for someone using a smaller amp.
