No radio reception after Biketronics Amp install.
Ok, I installed the biketronics amp the the PO had in the box of parts. I'm guessing he uninstalled it for some reason perhaps the one I found. I've tried two different powered amplified hidden antennas, the one that came with it (blue wires and an unlabeled silver box) and a biketronics hoggtenna. I can't get anything for reception with either one. I've got the hoggtenna in there now and it's placed as far as I could get it from the amp. is there anything I could do to improve reception?
It's a biketronics 454 2 channel amp. I don't have a whip antenna to try (came with the internal antenna). I'm using a power source from the bottom of the fairing by the headlight (two female spade type connections on separate wires) where the original antenna was pluged in figured this was better than using the cigarette lighter which is also being used to trigger the amp (blue wire)
