Controller or Radio? Best Guess?
Hello,
Another controller won't work situation. Installed an Alpine 149 deck. (Awesome BTW) Ordered a Biketronics 1002 by mistake (ad wasn't clear that it was Sony only...my fault) Hooked it up to the Alpine and obviously no go. Decided to save the 1002 for the wife's ride and I'll get her a sony soon. I ordered a Hawg Wired controller for the Alpine. Got is all hooked up and guess what...no go! Re did it several times and still no go. Could the Alpine's SWC input have been fried in some way using the Sony Biketronics unit earlier? What would you do? Can't call right now but need a plan of action.
Thanks!
Thanks!
Hmmmm...I have the Alpine 149 with the Hawg Wired controller as well.
I recall the instructions being very specific about setting the switches in the "Alpine" configuration before hooking either harness to it.
I know there is a way to reset the unit but I don't remember exactly how. I would try disconnecting the battery for a few minutes and also push the reset button on the head unit behind the removable face.
after you set the switches on the device, unplug ALL wiring to it. Let it set for a few secs and then plug it back in. As stated above, the instructions are VERY specific about setting your switches PRIOR to plugging anything into it. The BT 1005 controller is the same way.
ROCKOUT Rocker Products
2014-2023 Touring Models
21
10-10-2015 07:08 PM
vhmike73
Audio Systems
02-12-2015 03:37 PM
