Hi Level Outputs RF PBR300X4
if you haven't gotten it already, this is a pretty straightforward install.
install your radio
mount your amp on top of the radio
run a 10ga power and ground wire directly to the battery with a fuse for the power wire
take the blue/white (amp remote) striped wire on the back of the sony and connect it to the REM on the power plug. this turns the amp off and on with the radio.
connect your RCA cables from the radio to the amp
then wire your speakers to the amp.
on the amp:
the white wires are left front speaker
the grey wires are the right front speaker
the green wires are the left rear speaker
the violet wires are the right rear speaker
then set your gains.
install your radio
on the amp:
