speaker upgrade questions for street glide
what kinds of options do i have if i want to upgrade my street glide to 6.5" speakers? i really dont know much about audio beyond the basic concepts of installation
1) what makes the speakers sold at J&M/Biketronics/Hogtunes/etc special? are they weatherproof? why do they cost minimum $200+ for a pair as opposed to car speakers?
2) why not use car speakers? what risks are their in installing some regular alpine/kicker/rockford fosgate/whatevers?
3) is it feasible to upgrade the speakers now, and add an amp later if i decide i need more? or would that create complications?
my issue with the stock speakers isn't volume, they're plenty loud, but alot of the music i listen to sounds awful on them, even at a standstill some artists are borderline un-listenable.
I have a Sony head unit so 4 ohm is fine for me and I am running Hertz speakers which are fantastic, there is no issue with running car speakers, in fact I would go so far as to say that there are no bike specific speakers, but claiming they are bike specific is a great way to increase the price. There are 2 ohm car speakers out there.
HDSG12 (02-20-2021)
Most of the bike speakers are water proof.
Other than that no two people have the same ears so sadly you have to go by trial and error for what you can afford and what you think sounds good. Most speakers can be run without an amp but to get a better than stock sound an amp will be a night and day difference. I'm sure if you search and read up on positives and negatives of each of the speakers your thinking of using you will get a better opinion reading negative posts. They tend to bring out a more honest review than someone that just spent to much and being embarrassed by how there over priced system sounds.
I've only tried a few different speakers, but plan to try others just for the hell of it in the future. So far the more expensive haven't over performed the cheaper options in my experience.
But I do run an amp, and have a second amp I plan to install soon. My system sounds fine now but I can't leave well enough alone it seems.
Good luck with your search!
you have plenty of options out there. Simply pick what you like. Make sure to get a speaker that does NOT have a paper material for the woofer.
nothing really aside from R&D in a motorcycle environment. And if you notice there are LOTS of people in this audio section that are using JBL, Infinity, Kicker, Rockford Fosgate, etc. It's all a matter of preference and what you think sounds good to you.
see above
if someone comes to me for advice to install a system in stages as you're asking here, I ALWAYS tell them to go for speakers first and buy the best you can afford to buy. This sets the stage for further upgrades later on without having to worry about changing speakers again. The only thing to be leery of is if you're running a stock head unit, it is rated for 2 ohm speakers so if it's going to be a while before you add an amp, you'll want to stick with 2 ohm speakers like the Infinity Kappa 62.11I and then later on you'll need to make sure the amp you add to the setup will handle a 2 ohm load. There are plenty out there that will and the PBR300x2 comes to mind.
well I'm not sure what kind of music you're specifically talking about but if you're listening to any kind of hip hop, rap, etc. type stuff you can forget about bass response unless you add in the proper equipment to handle that efficiently for you.
see above
The J&M ROKKER XX option is here http://www.jmcorp.com/ProductDetail....=HCRK-7252-RXX ,,,,, grills with mounted tweeter and midrange here http://www.jmcorp.com/ProductDetail....ctID=HCRK-GRTM ,,,
The ROKKERs were designed SPECIFICALLY for the Harley bagger application and it shows ,,,, 2-ohm impedance, very high power handling capabilities, lightweight but strong Neodymium magnet, and waterproof poly cone ,,,,,
very close behind the ROKKERs are J&Ms Performance series, also designed specifically for the Harley Bagger application, with 90w RMS power handling, these will provide 90% of the sound & performance attained with the ROKKERs for about 65% of the costs ,,,,,, see http://www.jmcorp.com/ProductDetail....D=HCSK-7252GTM ,,,,,
Ultranutz makes a good point on adding the speakers first, but when you do, have a good idea of how much RMS power you want to add in the future, so that you don't purchase TOO MUCH speaker for the application or NOT ENOUGH ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
I haven't seen a 'top of the line' speaker, such as the K series Focal, or the BA Pro SE 60's, outperformed by anything cheap.
The best way to shop for speakers, is at a high end audio shop. Your ears are the best judge !!
I'd like to see your 'list' of speakers you've tried.........More times than not, you get what you pay for,...................unless you are comparing $59 speakers to $99 speakers..........
I didn't read anywhere that the OP wanted a monster sound system, just that he wanted something better than the stock speakers. That can happen without buying the most expensive system money can buy!
Not trying to sell him on booms, but the only people that have issues with them are the guys that take up there whole tour pack and saddle bags full of amps. Booms are not for these people. But for the mass majority of people that use there bikes for touring not bike shows can use cheaper speakers and be more than happy.
HD Rollin ,,,,,,,
when you use the J&M ROKKER XX speakers, they have the highest RMS power rating of almost any speaker available ((156w RMS continuous)) ,,,, however, the J&M ROKKER XT amplifiers need to be adjusted properly to take full advantage of the capabilities of the ROKKER XX speakers ,,,,,
get back to me direct at john@jmcorp.com and I will help you with the adjustments ,,,,,,
