Splash Cover Good Enough?
Making plans for swapping out the HK unit for an after market deck. Found some splash covers out there, but will they be good enough or should I also focus on only Marine units to avoid water damage as much as possible? If the splash cover is good enough my options for a head unit expand tremendously.
Thanks.
Thanks.
Marine grade is a joke sir. The 1 part of the unit that will be more susceptible to water intrusion than any other is the face and there's nothing marine grade about any of the faces of these units.
I would focus on what you want and need for features. The Biketronics retro radio kit (BT1002 for your bike) is one of the best out there. Another option for the splash cover itself is use the Biketronics handlebar control but the VTWIN Audio mounting kit.
A lot of guys use whatever head unit they like because of the features. I will be using the V-twin splash cover when I change mine out. Pretty thick, has a gasket around it, and looks great against a black painted inner fairing.
Marine doesn't mean totally waterproof. The only positive I can see with a marine unit is the display is usually easier to see in direct sunlight.
The Biketronics control were always in the plans, but thanks for the suggestion to check out the Vtwin splash cover...had not considered that one.
Plan is to use RCA out to my RF 300X2. Need media box to plug in iPod...otherwise the main consideration is build quality especially mounted in a vibrating HD.
these head unit will hold up fine. My only concern has always been retractable/fold out touchscreen units but they seem to hold up well also.
Everything I've read on here suggests that the pbr amps sound better when using the high level inputs, even if RCA's are available.
