You joined the forum in '08, and put Hogtunes in your '12..... shame on you.........
How much do you want to spend this time around ?? That will help guide your choices !!
Lot's of good options for every budget. From the insane set-ups , to the kick azz upgrades, they'll all blow away your Hogtunes !!
All in what you are willing to spend. And often times than not you can put something together that will sound a lot better than off the shelf setups for less.
I would go with Biketronics. Made in USA with lifetime warranty. I currently have Biketronics BT4180 amp, with the Biketronics 7.1 in the fairing. Ordered CVO pods for the lowers with Kicker CS67. Also have the CS67 for the rear pods.
