polyfill?
#33
I have focal krc 165's attached to the BT brackets, how do I attach the poly? Unscrew the speakers and stuff it between the speaker and bracket then poke holes through the poly to tighten the speakers back up?
Also, for anyone else installing these crossovers, if you put them where I did, use a zip tie to secure them. When I removed my fairing I found both crossovers hanging as the supplied tape came unglued, I cleaned the surface of the bracket with denatured alcohol as I do all surfaces prior to any adhesive and it still failed.
I guess you could drill and tap the bracket and use machine or self tapping screws for a cleaner install but zip ties were good enough for me.
