Sony n pbr300x4 cutting out
Hi all!
My friend asked for my help with his radio install on road king. Source is iphone, sony head unit, the goes to the RF PBR300x4 driving a pair of kickers 6x9 on saddlebag lid. The installer did a half assed job by using 10 awg power cable and maze like wiring. Now the problem is head unit and amp cutting out when the engine rev to 3500 rpm and above. I have measured batt voltage at 3500 rpm and it was 14.2V so I didn't think it was over voltage or anything, everything also cut out when the volume is cranked beyond 60% even on idle..
Apart from rewiring everything with proper wire, what should I look for to solve the problem? Don't wanna rewire everything and ended up with same problem.
Thanks in advance folks!!
go with what Pioneer74 said on the speakers first before you do anything. That amp is ONLY capable of running a 4 ohm load at each of the 4 channels. Aside from that, here is what I would look at.
the higher you crank that volume, the more current has to flow from the ground to the amp back to the battery. So you have power wires to look at as well.
1. if the installed did such a crappy job on the wiring then I would first take a look at the main power wire and make sure the fuse holder and terminals used are good, appropriate, and not jacked up. Bad connections in electrical wiring make for fun troubleshooting.
2. take a good hard look at the ground location and the ground wire itself. It MUST be the size of the power wire, in your case 10ga.
As I stated above and you might be scratching your head about; Despite what most people think, power does not flow from + to -, but just the opposite.
It is Kuryakin injection molded saddlebag lids with 6x9 Kicker speaker with separated mounted tweeter. Not sure about the ohm, website doesn't say anything about ohm and I didn't check the specs from the actual speaker yesterday, I will look into it. However, if the problem is with speaker resistance then only the amp will cut out right? Not the entire system?
Thanks a lot!
Harleypingman
Audio Systems
131
06-14-2016 07:03 AM
