MB Quart CD113 Specs?
The faring speakers installed in my EGC are MB Quart cd113 4Ω speakers running off of the stock HU. Maybe someone with better google-fu can help me identify the power ratings for these speakers, as mbq's website doesn't list these speakers (installed maybe ~2002 or so). Best I can find is someone's random kijiji listing in Canada saying 90W, but I'm not sure.
Figured out they're 35-90w.
Would the PN4.520D at 100w/ch be overpowering for this application?
I had the original idea of just going with an Ultra-pulled radio from the same vintage and adding tourpak pods/speakers, all with no amp, but when I see the headunit I need going for $400 on ebay (plus $200 for pods and $100+ on a pair of speakers), maybe sticking with what I've got and amping with the soundstream for $109 on amazon is a better half-step forward until I can add the rear speakers.
you'd be better off using the Rockford PBR300x2 for a 2 speaker setup. That SS will way over power those speakers. Later on if you add more speakers as long as you stay with 4 ohm speakers, you can wire them in parallel with the fairing speakers and still use the same amp.
