Radio Cuts Out
Radio Cuts Out
I have a 2009 Ultra Classic with a stock radio and the radio will cut out going down the highway. Not when I hit a bump, just riding and then no radio. I click the radio switch back and forth and the radio comes back on. I am thinking maybe a wire wore through and when it touches it cuts off? But if that was the case, the radio would not come back on after messing with the switch? Is the radio switch going bad?
Any help would be greatly appreciated!
While rocking the switch, does the icon on the faceplate change?
If it does, most likely the radio
Does the speaker icon on the radio appear when the radio cuts out?
If it does, it can be a switch or harness, call us if that's the case and we'll walk you through a couple of things.
It is acting like vibration damage. More common on the 06-08 because of the bad brackets, but the 09 is susceptible to the riser bolt issue.
If you need more info, feel free to give us a call
Highly unlikely it's a switch issue.
iron cross audio is THE BEST for Harley HK radio repairs ,,,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
