Please help noob finish amp install...
I have most everything done correctly so far but am lost with how to get the signal to the speakers now. The step X step I have been following were for the 07 SG but they have led me astray on some speaker wire colors and now I am just lost. I have an 09 Electra Glide Classic and am using the stock head unit. I installed 2 MM651's in the fairing and am now trying to figure out the speaker connections. I cut off the plugs from the old speaker connections and have wired them to my line level to RCA adapter. 2 RCA Y's are going from the adapter to the amp. I have the wires hanging from the crossovers from the MM's and would assume those connected to the speaker block on the amp but the instructions I find say something about more colored wires and harnesses....HELP! Feeling dumb.
your black and black/white striped wires go to the front amp outputs.
black/white on each side is your + lead
the other end of the wires coming out the crossovers with connectors on them go to the speakers. Pay attention to the connector sizes as they only go on 1 way unless you force them.
Well.....
Got the amp and speakers installed and WOW! Major diff! While I was at it and had the whole thing torn apart I went ahead and installed my L.A. Chopper Twin Peaks bars. Looks great but....
I have this piece left over....where does it go? I think it was somewhere around the tank:
I noticed the same thing when I did my install.
