Blew PBR300x2 or Polk mm651's for second time this year
Old 09-21-2013, 04:19 PM
SmittyFXDL's Avatar
SmittyFXDL
SmittyFXDL is offline
Default Blew PBR300x2 or Polk mm651's for second time this year
Last Dec I ordered and installed the Rockford Fosgate PBR300X2 and Polk Audio mm651 speakers. All was good until last May-ish. Blew the speakers and sent back and got a new pair replacement.
Was sick since June and barely rode half a dozen times til today. Took her out for a spin today and the audio was typically loud as usual but then would cut down like amp was cutting out and sounded very tinny like nothing but treble was on, and only out of one speaker.
I thought maybe loose wire so I shut down the tunes til I got home to inspect.
It doesnt sound like amp is powering sound, and theres sound from left speaker and just barely from right. I tried swapping wires to make sure its a speaker issue and only left worked again with right being barely audible.
So, where do I go from here? Any other testing or trouble shooting suggestions?
I am going to try and wire amp to old stock speakers and see if that kicks amp in but am doubtful at this point. Just trying to rule out areas where possible.
UltraNutz HELP!
Old 09-21-2013, 04:23 PM
FXDWG12's Avatar
FXDWG12
FXDWG12 is offline
You swapped wires and problem stayed the same. Sounds like speaker problem. And maybe have your gain set to high?
Old 09-21-2013, 04:47 PM
Pioneer74's Avatar
Pioneer74
Pioneer74 is offline
If you switched the wiring between speakers and the results are exactly the same, it must be the speakers.
Old 09-21-2013, 06:16 PM
SmittyFXDL's Avatar
SmittyFXDL
I swapped out and hard wired stock speakers to amp and it sounded loud and clear. Not an amp issue from what I can see.
My settings were HP, Gain was 5 1/2 - 6 and Freq was just over 100.
Looks like the Polk Audio mm651's are going back. This will be third set in less than a year. Are my settings that far off to be blowing these speakers or what?
Old 09-21-2013, 11:14 PM
Sire2Twins's Avatar
Sire2Twins
Sire2Twins is offline
Seems that if you have set to HP, your gains and frequency are too high. try setting gains at 5, freq at 60-80 and AVC at 2 bars.
Old 09-22-2013, 08:25 AM
acchd's Avatar
acchd
acchd is offline
Unless your a gluten for punishment choose another speaker too many reliability issues reported with speakers ur using.
Old 09-22-2013, 11:03 AM
1sweetglide08's Avatar
1sweetglide08
1sweetglide08 is offline
Get a set of Biketronics 7.1 with a lifetime warranty and be done.
Old 09-22-2013, 07:54 PM
SmittyFXDL's Avatar
SmittyFXDL
Had AVC at 2 bars. Could that slight difference in gains and freq make that much trouble for the speakers to handle? I thought the polks were more than capable of handling the power and amp. Its not like I had the settings maxed out. Im still trying to understand watts, ohms, and how they all work together.
Old 09-22-2013, 08:31 PM
Sire2Twins's Avatar
Sire2Twins
I am by no means an expert on this. Just thought I would regurgitate what others have shared and seem to be happy with.
You mentioned that you were running slightly over 100hz with it on HP and gains over 5, so just offered it as a possible adjustment that might make a difference. Personallly, I have mine set on AP with gains at around 11 0'clock position. Set gains using the by ear method. Been running the Polks daily for several months now, as I commute to work 100 miles per day. I push mine pretty hard in all kinds of weather and have not had any problems. Purchased them around the same time many of the others that are complaining about the Polks did, and have been trouble free. I also listen to a lot of hard rock, which is supposed to be harder on these speakers. Just makes me wonder how hard folks are pushing these things to have all of the problems that are being talked about.
I won't discount possible bad batches, or other issues, but mine have the same batch numbers that have been discussed as bad on this forum. I have also seen a lot of people say they "blew" other brands of speakers in these forums too. IMO, there are way too many variables that can contribute to audio problems to say everyone is doing the same thing.
As others have mentioned, if you have to replace anyway, might want to check out the BT 7.1's. If I had that extra spending money, that's the route I would want to take, but I'm on a budget.
Old 09-22-2013, 08:54 PM
Pioneer74's Avatar
Pioneer74
Ohms - Resistance
Voltage - Force
Amps - Current
Watts - Power
When discussing our radio systems, the voltage is the only constant. 12 volts. The resistance is usually either 2 or 4 ohms. The lower the resistance, the more amperage that is drawn by the amplifier. The higher the amperage, the higher the wattage.
This might help a little.
http://science.howstuffworks.com/env...uestion501.htm
Quick Reply: Blew PBR300x2 or Polk mm651's for second time this year
