Head unit help....
Head unit help....Which one??
I currently have a Sony head unit, model # DSX-MS60, with the SS amp, Biketronics Retro Radio kit. Problem is.. I really like the Sony head unit with the built in Ipod cradle but really dislike the features on the deck, planning my winter projects now so my question is... what head unit are you running ? What unit would you suggest and why?
Thanks in advance.
Thanks in advance.
Well, I installed it last winter, everything was good until recently, now its sometimes wont read the Ipod, displaying error messages, the shuffle mode wont stay on, and the automatic volume control has a mind of its own. (could be the Biketronics kit) just unhappy with overall performance.
1.) if you're unhappy with the biketronics controller simply call Bill. He'll replace it
2.) If you're having issues with your iPod not being recognized then you should get to the root of that issue before throwing $ at another head unit only to realize the head unit may not be the problem. Check the USB to iPod connector and the USB cable.
Have you tried plugging in your iPod to the front USB port instead of inside to see what happens? Odds are if you experience the same thing on the front USB connector using an iPod cable then the issue might be the iPod itself. What model of the iPod is it?
As for the Biketronics controller, its been working great all summer, it just started having a mind of its own with AVC. Im stumped!
Arseclown
Audio Systems
06-22-2016 11:01 AM
