Stupid question
Old 09-11-2013 | 02:02 AM
ridedaddy's Avatar
ridedaddy
Default Stupid question
What is the downfall to running a 8ohm speaker of of my 2 ohm head unit? Sorry if this question makes you audio guys cringe but I'm just not really a audio guy. Maybe if someone could explain speaker ohms to me it would make more sense?
Old 09-11-2013 | 07:26 AM
UltraNutZ's Avatar
UltraNutZ
i'll give you the very short version of this.
It's ok to go up in impedance/ohms but not down. So if you have a headunit that is stable at 2 ohms, it's ok to go to 4 or 8 ohms but you cannot go to something like a 1 ohm speaker. You'll toast your outputs on your head unit.
The drawback to using 8 ohm speakers is you will wind up at a much higher volume level (bars on display) to achieve the same sound you would out of a 2 ohm speaker to achieve the same sound level. What this does; because the volume level has to be turned up higher is starts to inject distortion into your audio. This is not a good thing as distortion is what kills speakers probably 90% of the time vs what most people think is power killing them.
I would at a minimum suggest a good 4 ohm speaker to put in your fairing. There are a lot of good 4 ohm speakers out there and at very inexpensive prices. 2 ohm speakers and 8 ohm speakers are hard to find these days.
I put a pair of these kickers in a road glide a couple of weekends ago and they sounded pretty decent and a much improved sound over stock. And at $69.. that cheap for decent sound.
Old 09-11-2013 | 10:56 AM
ridedaddy's Avatar
ridedaddy
Thanks, I have a few sets of polk Dxi650 laying around and was thinking of using them till I am ready to spend some money on my audio.
Old 09-11-2013 | 10:58 AM
UltraNutZ's Avatar
UltraNutZ
yeah those are good speakers as well..
Old 09-11-2013 | 04:04 PM
zion's Avatar
zion
That was a great, concise and clear explanation!!
ROLLNTIGER
Audio Systems
05-24-2014 02:27 PM
Scooby1426
Audio Systems
05-13-2014 01:43 AM
chidiver
09-11-2011 03:41 PM
John_HD
09-21-2010 08:15 AM
omahairishfan
06-03-2007 03:36 PM
