Which speaker lids?
1 Post
Which speaker lids?
Im sure this has been asked somewhere on here already but i cant find it at the moment so sorry if it has.
Im after some additional tunes on my 95 Road king, I have a memphis shades fairing with the hogtunes setup for when im doing long journeys and love it, can hear clearly at motorway speeds etc etc. Trouble is i dont have the fairing fitted unless im doing motorway miles and miss the tunes, so what i want is something thats there all the time and will compliment the fairing set up when i have it on, hence a set of bag speakers, I have ruled out something on the bars as it will be in the way when i stick the fairing on, i dont run front crash bars so lowers etc are out of the question.
I have looked at the Kuryakyn set up and the Hogtunes set up and at the moment am leaning towards the Hogtines because of the angle of the speakers and the overall look of them, what else should i look at, i specifically want something that i will here when the fairing is off so directed at the rider (dont do passengers)
Thanks All
Thanks All
ah ok gotcha now.
well here's what I'd do if in your shoes.
Hogtunes lids (call Pez directly instead of ordering online)
Pioneer TS-D6902R 6x9s
Soundstream PN2.350D
"y" off your inputs to your existing amp and run to rear and put SS amp in saddlebag. This thing is really small and packs one helluva punch and is a great amp to drive those Pioneer speakers with.
you'll need battery, ground, accessory power to turn amp on and off in your saddlebag
1 Post
thanks for the input, much appreciated. Are the pioneer speakers that much better than the ones in the complete hogtunes kit? would the complete kit with the SS amp work?
Im in the UK so getting the complete kit from a uk Indy and then the SS amp from the states works out a whole lot cheaper as i cant get the Pioneer speakers in the UK (as far as i can see)
cheers
cheers
1 Post
Just found the only pioneer 6x9 in the uk market is the TS-E6902i
spec as follows
Maximum output power - 360 Watt
Nominal output power - 80 Watt
Impedance - 4Ω
Frequency response - 28 - 30,000 Hz
Sensitivity - 90 dB
Woofer size (cm)16.3 x 23.7 cm
Woofer material - Dual Layer IMX™ Aramid & Basalt Fibre Cone with Butyl Rubber Edge
Tweeter size (mm)28,0 mm
spec as follows
Impedance - 4Ω
Sensitivity - 90 dB
if you can't find the SS anywhere, go with the Rockford Fosgate PBR300x2
According to what I'm find on the web, there used to be a Soundstream dealer in Bolton.
I'm seeing that if you contact these guys @ www.caraudiosecurity.com they will order Soundstream stuff for you.
How to find our store
CAR AUDIO & SECURITY
Unit 6A Bilton Way (off Pump Lane),
Hayes, Middlesex UB3 3NF
Tel: 020 8561 9485
Fax: 020 8848 7175
Registered in England No. 374 00 69
VAT No. 735 7582 04
Opening Times:
Mon .Sat: 9.30 . 6.00pm
Thursdays till 7.00pm
Sundays: CLOSED
To place an order / Order Tracking / Product Enquires / Book an installation please call:
Phone: 020 8561 9485
For returns details and address, please call:
Phone: 020 8606 0638
Tel: 020 8561 9485
Fax: 020 8848 7175
VAT No. 735 7582 04
Opening Times:
Sundays: CLOSED
