Whole lotta info needed.
Over the fall winter I'm gonna redo my sound on my road glide. I plan on putting in New speakers in the stock location, and wanted two more down on the sides of the inner fairing facing the forks. Planned on going with a marine deck. Also wanted to run an amp and an 8" sub in my inner saddle bag. Can I get sum advice on brands and any other advice....huge thanks!
check out glacier pearl's setup.
Start reading up on the threads - a ton of good info.
budget? Want to amp it (assuming so)? Are you sure you want marine? It's less features for $, with marginal more "waterproofing" (i think just the sticker...).
GP has 4 6x9's in saddlebags - i bet they are better than most dedicated subs (more surface area)... given enough power. Definitely check out the pioneers he recommends.
GL!
GL!
Moral of the story is ;
don't waste your $ on subs for a motorcycle. Simply not worth it IMO because the ONLY way you're going to get a sub to perform the way a sub should perform is to build an enclosure around it (i am not and never was a fan of "free air" koolaid BS), tune that enclosure properly, and amp it with a good Class A or B amp. Class A, B, and A/B amps are not good for motorcycles as they draw way too much current and produce way too much heat.
User 11821
Audio Systems
07-07-2017 10:49 PM
