PN4.520 - No sound to speakers
Experiencing a new issue with my setup. I have a stock HU with a SS PN4.520 amp and 4 MM651 speakers. I am getting sound out of the headset if I have one connected but if I flip the switch where i would normally get sound out of my speakers, I get nothing. Opened the fairing this morning to check all connections and fuses; they all look good.
Thoughts/Suggestions??
got a spare speaker (even a stocker) that you can connect to the output of the amp to see if you're getting any sound?
and if so, and you do have sound, then move the speaker to the end of the speaker wire behind the crossover (where the speaker is actually plugged in) to make sure it's ok as well.
if no sound then we'll have to go a different route in troubleshooting...
