Stock Speaker Size "13 Street Glide
Hello all, I have a new Street Glide and I am looking to upgrade the sound. I am not trying to compete or get into anything crazy, just want it better! What size are the stock speakers so I can get something without having to do a whole lot of mods. Any one useing a tweeter mounted in the dash with a cross over?
I was thinking a set of two way Kickers....
Stock Harley speakers are 5-1/4 2ohm. Really limits your options for direct replacement unless you move up to a 6-1/2 or 6-3/4 with an adapter ring.
I think you need to be a bit more specific on what you mean by "a whole lot of mods." Do you just want plug and play speakers? Are you considering adding an amp? This stuff is pretty easy given this forum and the folks here that will help you.
The adapter rings just screw right into the stock location and allow you to mount a larger speaker. As for tweeters, if you get a good 6 1/2 2 way with a built in tweeter you may find you don't need to mount separate tweeters. You could go with the hogtunes tweeter pod. It's plug and play but does require you to drill two small holes in the dash for mounting and running the speaker wire. If your dead set on separate tweeters you could also pull your air and oil gauges and put them in those spots.
me personally, I'd recommend;
- you take a look at the BT7P1 7.1" for your fairing. the adapters needed are also included so when compared to others, the cost difference is minimal.
- hold off on drilling holes in your fairing for the tweeter pods until you've got the speakers installed. You're likely to find you don't need the tweeter pod.
- if you decide you need the tweeter pods, you simply tie them to the already installed speakers and you're done.
