Harmon Kardon on 03glide??
I swapped my original 05' Harley "Radio Sound" to a new HK head unit with no problems plug and play. Then I sold that and now Im running a Sony head unit. I would say its not worth the extra money look into a good aftermarket head unit like a sony or some others will chime in. A good aftermarket head unit is the way to go for future audio upgrades and a much cleaner sound plus usually not as exspensive as a HK. just my 2 cents
to get the automatic volume control on the new stocker, you'll need to browse into the radio diagnostics for the speed control and change the setting. Can't remember from and to but there are only 2 settings, 1 and 2. whichever it's on change it to the other for analog operation of your AVC
98-05 use the high setting. (but 98-03 is analog and needs to be flashed)
06-13 use the J1850 setting
