6x9 speakers in saddlebags need more air? Port?
I wish mine would have came with a spacer ring lol. I just used 1/4 inch round by 3/4 tall nylon spacers so there is a 3/4 inch gap between the speaker and the side of the bag. No real way to seal it off completely unless I mount it directly with another spacer. Mine def sounds better with the lids closed so I'm not sure if I'm having the same issue or not. Lol
Well it's not the speakers. Something I did in the wiring to the amp.
See all these walk throughs on how to wire amps and speakers that I have read assume you have 4 speakers already. My road glide came with front only and I had front high inputs to use only which I feed all 4 high input channels with. I'm not sure if using the front high inputs into the amp and then running 4 speakers from the 4 channel amp has anything to do with it. The front infinity speakers jam its just the back. Im off to the docs for an appointment and then when I get back I'm taking front fender off again. I have a group ride this saturday and sure would love to get power to all 4 speakers. Ive never been this lost in all my audio installs, of course this is the first bike.
I think your problem is you didn't drill enough holes in the back of saddlebag. It looks like, in the video, you have less than 20% open area in your speaker location. Not enough holes equals poor sound quality. If I were you I'd drill another row of holes in between the ones you have already.
Good point. While I did not listen to mine before I did it. I went back and doubled the number of holes.
I started with this...................
And I finished up with this.
OK so I'm a dumbass.
You look at an amp and it has:
white / white black
Black / Black white strip
Green / Green Black strip
Grey / Grey black strip
...and assume....pay attention here. I said ASSUME that the strip is negative as it typically is. NO! The soundstream amps are negative every other strip and positive every other striped wire so I had all my speakers hooked up half *** backwards. They all sound amazing now.
Sorry to trouble everyone and take up precious minutes of your life because I assumed.
white / white black
