Is Polyfil and a dampener (Dynamat J&M Pads) both required?
Hi,
waiting on my Titan II's 7.1's to get in and was curious.. I already have the polyfil... should I also get some dynamat or J&M foam as well for the faring? (Batwing)
use the polyfil.. the foam does something totally different and no where near as effective as polyfil.
Ditto. I had the J&M Foam liner for the batwing. Far as I could tell all it did was waste my money, and reduce the space for the wiring harnesses inside the fairing. The only noticeable difference came when I added the polyfill as recommended by Ultra. Dynamat IMHO is a complete waste of money. A friend put that heavy crap in and there was no difference in sound quality that we could tell.
I am one that was suckered into the J&M foam liner. I agree with the waste of money and taking up space for the wiring. My question is this: should I try to remove it now and use only the polyfill or will it be ok to leave it along with the polyfill?
I was afraid someone would say that. That is a lot of sticky backing to remove. One of those things that you know is probably the right thing to do but you just don't wanna
