Tweeters..
Amazon.com: Infinity Reference 1031t 1-Inch, High-Performance 150-Watt Textile-Dome Tweeter (Pair): Car Electronics
stumbled across these.. seem like a better fit for the system.. just unsure what size the ones in the hog pod are.
That's a good idea Drew!!
I have the Hog pod too.
It's ok.....but could be better for the high's I think?
You could also just scrap the Hog Pod and put them in place of the gauges by the radio.
I had the HT speaks in my fairing too and thought that they were over-rated as well and no longer have them. I have Kickers in their place and they are better for high end too. I have the little HT Amp, and it's ok.
Only problem is the holes that are left from the hogpod.
Yes, when I replaced my fairing speakers with HAT Unity component 6.5's i had a buddy install the tweeters in the Hog Pod after I removed the HT tweeters. Works great.
Suggestion: Measure the HT tweeters diameter and buy a similar size tweeter separately, or components that include a tweeter of similar size.
Carl
Carl
Finally had some time and tore into the fairing again.. Wrapped the speakers with some polyfil and tore apart the hogpod....
Looks like the tweeters are 1 1/2 inches would be an easy swap due to a crossover already mounted in the pod..
I will keep y'all updated if I decide to swap out the tweets..
Carl
