Please explain.. what's with these adaptor rings
Old 05-27-2013, 03:52 PM
thelawnmowerman's Avatar
thelawnmowerman
thelawnmowerman is offline
Default Please explain.. what's with these adaptor rings
I'm fairly new to this audio thing, and i'm reading about people needing adaptor rings.
I have a Deadcenter cycles fairing with Polk db651 speakers fitted and I'm going to change them for MM651 speakers, will I need these ''Adaptor rings''
Old 05-27-2013, 04:22 PM
sl33py's Avatar
sl33py
sl33py is offline
If they fit the DB651's, they should fit the MM651's. Both are 6.5".
HTH - GL!
Old 05-27-2013, 06:27 PM
rbferg's Avatar
rbferg
rbferg is offline
Old 05-27-2013, 06:30 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
No sir you don't need adapter rings. These are only for stock fairings where the speakers mount from the rear. Your speakers will drop into the front of the fairing.
Old 05-27-2013, 06:31 PM
ducatidesmo's Avatar
ducatidesmo
ducatidesmo is offline
The adapter rings are mainly for the OE farings (batwing and shark nose) as they have 5 1/4 inch holes, so you either get another 5 1/4 or you use a 5 1/4 to 6 1/2 inch (or 7.1/7.25 depending on who your going with) adapter.
Old 05-28-2013, 10:27 AM
vtdiesel's Avatar
vtdiesel
vtdiesel is offline
So adapter rings are needed for OEM inner fairings because they bolt from the rear? On lower fairings they bolt from the front? So adapter rings won't be needed on lowers?
Old 05-28-2013, 10:31 AM
UltraNutZ's Avatar
UltraNutZ
you are correct sir...
Old 05-28-2013, 10:32 AM
vtdiesel's Avatar
vtdiesel
vtdiesel is offline
^thank you, I am trying my best at understanding this all as I put my parts list together for my system.
Old 05-28-2013, 10:33 AM
UltraNutZ's Avatar
UltraNutZ
no worries sir.. ask questions all you want.. better to be informed before you get into it.
Old 05-28-2013, 10:44 AM
vtdiesel's Avatar
vtdiesel
vtdiesel is offline
I am planning to go with your previous suggestion UltraNutZ and going with 4 Polk mm651 for the inner and lower plus a slipstream amp.
Quick Reply: Please explain.. what's with these adaptor rings
