HK Head unit or Sony
BT also provides for many different aftermarket head units (pretty much anything with steering wheel control inputs) with their universal kits as well, just like HW does.
I've used BT since I started putting audio on bikes back in 05 and never had a single problem with any of them so unsure about the issues you raise.
I do agree with the HW cover being a little better quality and it looks better too IMO and the mounting kit looks (never used one) to be a little more sturdy as well.
I will also say that both devices are of excellent quality and both companies stand behind their products very well. I would say out of all the folks here on the forum, I'd guestimate probably a 50/50 split for each manufacturer and I don't think anyone for either device is unhappy with it.
Some people have gone with the Hawg wired mounting and the Biketronics controls, the Hawgwired mounting is made better, you may also want to do a little research, there have been mixed reviews on the elecronics of the Biketronics. I don't know about Biketronics but Hawgwired has a universal adapter that allows you to use other brands like Kenwood, Pioneer, Clarion, Alpine, etc. Also the water cover for Hawgwired is more expensive, but far superior in quality, I know, I have both. I must admit I'm biased toward Hawgwired, but do the research and check it out.
I am ordering now from sonicelectronics and was wondering if I should order an amp install kit, it says 10guage wire needed for install.. is there anything else I will need to order just so I will have everything when I go to install all this, I am buying a head unit also but not sure which one choices choices lol
would this head unit work? http://www.sonicelectronix.com/item_...VX77.html#tabs
what radio install kit should I get biketronics or hawgwired ? HW looks like it will be more sturdy for the HU
are these the right speaker
Get the Hawg Wired 'cradle ', ....and the Biketronics 'module' !!! Best of both worlds !!!
Call Biketronics, @ 1-800-735-2419, and get a price on the BT1005 module ONLY. They list it with the install kit on the website, not separately. However ,.....they do sell it separately.
Hawg Wired radio install kit DK470 is easily ordered from the Hawg Wired website !!
Don't forget the Cycle Sounds Speaker Adapters !!
Good Luck !!
Good Luck !!
danzio
Audio Systems
13
09-13-2016 08:06 PM
