PBR300X2 + J&M 7.25's???
anyone have the luxury of installing this combo? I'm attempting to put it on my 08 SG and just don't want to mess up the wiring when I go to soldering! Pics would be great as well!
Looking thru UltraNuts' sticky above and comparing the rf amp with the polk speakers is gotta be very similar. the directions call for a white/brown speaker wire well my wire is white/orange is that the same? also it calls for on the same side a white/green speaker wire but mine is green/white? These are the stockers that are plugged into the J&M's currently.
Thanks in advanced
Thanks in advanced
here is a couple links to the products
http://www.rockfordfosgate.com/produ...?itemid=225197
-scroll down to the wiring wizard link, which diagram would best suit these speakers
http://www.jmcorp.com/ProductDetail....D=HCSK-7252GTM
specd at 2 ohms impedance & 140+ watts max power
Thanks in advanced
Thanks in advanced
sending the J&M's back
thanks for the help gotta go with what works right!
you'll be very happy you went the route of the Polks...
What speaker wires are you referring to? I think what you're seeing is the jumper wires that were provided by J&M. The stock speaker wire colors haven't changed in many years. Something to keep in mind is the service manual from 09 on up has a misprint in it for the right front speaker wire +. It shows gray/red as - when in fact it's +
I'm referring to the stockers that plug into the J&M's. the J&M jumper for the tweeter is like 32 gauge! grey/red is + for right side which is + on the left side? asked that for install purposes!
They come with the adapters and they will Rock the House!
Oh well.................
