Speakers.....
Hey all, Just finished Blacking out the front end of my 09 street glide and installed 12" apes. Before I install fairing I want to upgrade speakers. I bought the 6.5" adapter rings and was wondering if there are any clearence issues with 6.5: speakers. Some manufatures make slim fit designs. Is this necessary? I was looking at MB quart and Polk audio speakers. The MB quart look really deep and concerned if it will foul with the fairing.....Thoughts? Input would be great.....searched the forum, and was unable to find anything.... Thanks in advance. Cheers.....
If you are using your factory head unit, without adding an amp, the MB Quart will not be a good choice, as they are all 4 ohm speakers.
Polk makes a 6.5" speaker in 2.7 ohms, which would work well with the factory radio & no amp.
If you are adding an amp,.........then that changes everything !
I haven't run across a speaker that interferes with the fairing cap yet, MB Quart included. GP has you covered with correct advice..
Stock head unit and simply replacing speakers, you need to stick with 2 ohm speakers
As stated above, if adding an amp into the mix that changes everything however if you change speakers now, then add the PBR300x2 into the mix or later on as rbferg suggests is a great option. Amp, speakers, speaker adapters, and a little bit of wiring will run you about $350 and a little bit of your time to get it installed.
Gunner Buckshot (11-16-2022)
what's electrical tape?
I don't EVER use that stuff for anything.
On your wire connections lots of people like to solder and use heat shrink to cover the splice. I since 1985 have used 3M electrical connectors for everything except larger power wire installation such as 0 or 0/0 size wiring where crimping is simply not a reliable option. Having the proper tool to crimp with is essential as well.
Here's a link to the crimp tool I use.
http://www.amazon.com/Klein-J1005-Jo.../dp/B000936OTY
Here's a couple of links to the connectors
http://www.amazon.com/3M-Assorted-El.../dp/B0015G7OIY
http://solutions.3m.com/wps/portal/3...be86T5B1F0W5gl
![Icon Beerchug](https://www.hdforums.com/forum/images/smilies/icon_beerchug.gif)
