Power to radio
Power to radio
I have my entire fairing off and I'm trying to figure out what HAS to be connected to power the radio.
I'm trying to test everything before installation. I checked the 10 and 20 pins and there is no voltage. Is this something goofy like the headlight has to be connected or something? I have a 12 volt, 19 amp power source, the maxi fuse installed and the ignition set to accessory. Is there something I'm overlooking? The electrical diagrams aren't helping me.
which radio?
OK, so after testing about a dozen things, I realized I had two connectors swapped. Apparently there are two 12-pin Deutsch connectors that are similar. Swapped them out, now have power. Now to figure out why there doesn't seem to be power to the speaker switch (at least it's not lighting up) and how to access the fader.
