Audio system upgrade
Old 05-11-2013, 10:33 AM
zxport123's Avatar
zxport123
zxport123 is offline
Default Audio system upgrade
Hello HD Forum Members,
Looking for advice on stock audio upgrade 2002 Electra Glide Classic, here is what I have in mind for utilizing a two speaker set up only with no further speaker mods in the future.
1. Sony CDX-GT710HD head unit ( Can use usb jump drive to play numerous music selections).
2, PBR 300 x2 Amp
3. Polk MM651 marine speakers wrapped in polyfil.
4. Dragonfly or Arc audio speaker adapters.
5. Radio install mounting kit (Hawg wired or Biketronics)
6. Scott Ezell mounting bracket for the amp
7. The Sony remote will be used to operate the system.
Old 05-11-2013, 10:53 AM
UltraWalt's Avatar
UltraWalt
UltraWalt is offline
2, PBR 300 x2 Amp
You will enjoy this set up but would be willing to bet you will look to add to this 3-6 monthsd later.
Old 05-11-2013, 11:04 AM
zxport123's Avatar
zxport123
If you are correct, what other audio set up would leave me room for future mods?
Old 05-11-2013, 11:55 AM
zxport123's Avatar
zxport123
Question Front fairing speakers
Hello HD Forum,
Can the Polk mm6501UM speakers be used as a replacement for the front fairing speakers on a Electra Glide Classic powered by a PBR 300 x 2 amp, both are 4 ohm set ups right? I am only trying to have a two speaker setup versus a four speaker setup. Was considering the Polk mm651 speakers but they are rated at 2.7 ohms, and don't know if they are compatible with this setup.
Old 05-11-2013, 12:28 PM
GLACIERPEARL's Avatar
GLACIERPEARL
GLACIERPEARL is offline
Those will work GREAT zxport, as the 300/2 RF is 2 ohm stable !
Old 05-11-2013, 01:19 PM
ep120794's Avatar
ep120794
ep120794 is offline
GlacierPearl which speakers are you refering to that will work great? The MM6501's or the MM651? How will the MM6501's work with the Soundstream amp in just a 2 speaker setup?
Old 05-11-2013, 02:00 PM
GLACIERPEARL
They will both work, but the MM6501's will shine with that amp !!
Old 05-11-2013, 02:06 PM
ep120794's Avatar
ep120794
ep120794 is offline
Will they shine equaly as well with the Soundstream, or better with the pbr?
Old 05-11-2013, 02:15 PM
GLACIERPEARL
If you have no intentions of upgrading to a 4 speaker set up, the PBR 300/2 is your best choice !
Old 05-11-2013, 03:35 PM
zxport123's Avatar
zxport123
Smile Front fairing speakers
Hello HD forum
Will the Polk MM6501UM speakers fit in the front fairing as replacement for the stock units on a 2002 electra glide classic
Quick Reply: Audio system upgrade
