interconnect harness
Old 04-26-2013 | 01:27 PM
Smock158's Avatar
Smock158
Stage III
Default interconnect harness
biketronics 1-800-735-2419 makes a adapter instead of buying a $300-$400 interconnect harness. I called them and they are custom making one for me for $45.00 that will work with my stock FLHTP harness.....comes with the 23 prong plug that you have to splice in and comes with the wires already color coded. they do not advertise it on their site, you have to call and ask for it. It saved me allot of $$$ and time to search for the 70232-08 needed for my bike
Old 04-26-2013 | 07:28 PM
UltraNutZ's Avatar
UltraNutZ
Great info Smock158 thank you...
Old 04-27-2013 | 09:55 AM
Harleypingman's Avatar
Harleypingman
Are you using civilian handlebar switches?
Also, that BT harness is a great value. I made my own about 6 years ago and connected it to civilian handlebar controls I installed on my FLHTPI. Took several hours of researching wiring diagrams and parts books. I did it to install a BT radio kit.
I later added HD cruise control, oil pressure and temp gauges. All of that required a lot of research time. Happily, everything worked perfectly.
However, I never really liked all the spliced wiring inside the fairing, so when I disassembled the bike for paint a few years ago, I found a used interconnect harness on EBay, bought it installed replacing all of the add on wiring I had added.
In hindsight, had I known I would be adding all of the civilian items I would have simply purchased the interconnect harness.
Good luck with your project.
Carl
Cage Dodger
Audio Systems
11-14-2013 05:57 AM
wils5150
Audio Systems
03-20-2013 06:50 PM
green53
04-12-2012 06:35 AM
jbhawley
03-01-2007 05:20 PM
Badwished
06-21-2006 05:36 PM
Quick Reply: interconnect harness
