Anyone close to Columbia, SC!!!
Need help making sure wiring on my 2008 SG is done right. My set up is 1)Sony MEX-BT4100P HU 2) Soundstream pn4.520 Amp 3) 4 Polk MM651 upper and lower speakers. Ultranutz gave me all kinds of good advice on how to wire them up. But I'm more nervous than a prostitute in church. But who wouldn't be after throwing away 8 Polk dxi 650's and a pair of cheap sonys. My wife will probably leave me this time if this don't work. Please help!!
in the stickys up top of the forum.. The very first one 2007 FLHT is going to be exactly what you have but a different model radio with the same RCA outputs on it as for the wiring. Also instead of following the steps for the rear pods, substitute that section for lowers
I give up Ultra. I followed the instructions step by step. I got stuck when it said about connecting the speaker wires to the amp wiring harness. The only wires coming from the amp is the hi input wires. They are solid colors. Would the wires you referring to will be hooked up to my biketronics adapter? Plus if I will be doing it that way the only wires hook to the amp will be the ground, rem, and power wire?
there are 2 versions of this amp floating around. 1 with a speaker wire harness the other with a terminal block on the side of it for the speakers.
connect RR+ to your right rear crossover black/white wire
connect RR- to your right rear crossover black wire
connect LR+ to your left rear crossover black/white wire
connect LR- to your left rear crossover black wire
connect RF+ to your right fairing crossover black/white wire
connect RF- to your right fairing crossover black wire
connect LF+ to your left fairing crossover black/white wire
connect LF- to your left fairing crossover black wire.
