Is there a doctor in the house? Paging Dr. UltraNutZ or another Road Glide doctor!
I have a 2001 Screaming Eagle Road Glide. I already yanked and tossed the cinder block sized skip-o-matic cd changer out of the tour pak. The HD am/fm/cassette head unit & stock Kraco speakers are next! I have new in the box the following;
RF PBR300x2 amp
JVC KD-A315 cd head unit
Kenwood KDC-MP538U cd head unit
Kicker PX100.2 amp
Kicker PS5250 dash replacement speakers (2 ohm)
HD speaker grills (old ones are shot)
The Kenwood unit has a USB input that will run an iPod. The Kicker stuff is all water resistant. I am wanting to add a second set of speakers, but... I can not find a set of speaker housings for the factory Road Glide lowers. I am considering some of those speaker pods that guy has on eBay for the Chopped Tour Pak, but at $200 plus another pair of speakers, I wanted to see what other options I have. Right now, I only have enough $$$ to buy an adapter/ install kit for the aftermarket head unit. What are your suggestions?
To recap, I can replace my head unit with either aftermarket unit (with the addition of a Biketronics or Hawg Wired adapter), either amp, and the Kicker speakers. If I found a useable housing for a second set of speakers, I could use them with the second amp.
All input welcome. Thanks!
RF PBR300x2 amp
Kicker PX100.2 amp
Suggestion: sell everything except the RF amp and the head unit you want to keep.
W/O glove boxes, I don't know of any speaker kit that will work with those lowers.
Also, get a better pair of fairing speakers that will likely require adapters to install.
Bottom line: It's better to have an excellent two-speaker system than a poor 4-speaker system.
Good luck with your project.
Carl
Carl
Carl
Carl
I agree on the fairing speakers. There's a lot better choices out there. A good choice for that particular amp would be the MM651 Polk Audio speakers
Thanks guys. I am definately on a tight budget right now! In addition to buying the SERG, I have been putting $$$ into my Softail. I just bought tickets to the 110th, did the 40K service with cam tensioners on the SERG, need a new tire for the Deluxe, and the warden has been hitting me with the "why aren't you ever satisfied?" speech!
So... right now I have enough to get the head unit adapter/install kit. That's it. Polk MM651's are on the list for sure. I need to use what I have, then will add on with probably a set of rear speaker pods since the lowers look like they won't pan out for me.
Two questions;
1) Will a set of the regular rear speaker pods work with my chopped tour pak? Or will I need to buy a set of those custom sized ones from eglidegoodies?
2) Can both amps fit in the fairing on my Road Glide? or, should I plan for another location for the rear amp?
Since the Kicker amp is water resitant (as are the speakers), I was thinking that I could mount the amp under the tour pak and have it run the rear speaker pods (when & if).
Your thoughts?
Two questions;
Your thoughts?
Two questions;
2.) So the kicker amp is 4.75" long, 2" high, 3.5" wide. the RF amp is 6.75" long, 1.5" high, 4.25" wide. With these measurements I would say yes both will fit right on top of the radio perfectly fine.
I would say not to do it unless you absolutely have to.
