Sony DSX-S210X + Sirus XM Onyx Hook Up
I am gathering parts for my 2010 Ultra Classic to do the Nutz Special. I am purchasing a Sony DSX-S210X head unit. I have a Sirus XM Onyx radio and docking station that I use in my truck. What do I need to hook the XM Onyx to this radio? Thanks for any help.
I used a FM direct connect module in my truck so that I did not have to search for stations.
I saw this
http://www.sonicelectronix.com/item_...t-Adapter.html and thought this might be what I needed to use to do the same thing with this Sony radio.
If you think I just need the RCA cable to do the FM direct connection I will try it. I just thought someone else might have done this and could give me some insight. The radio has been shipped and I will actually read the instruction when it gets here.
Thanks NUTZ for your help. I am sure I will have more questions once I get started on the NUTZ SPECIAL.
Thanks
Tim
I saw this
Thanks
Tim
you are partially correct sir. I have no earthly clue what I was thinking when I posted last time as I know this head unit does not have any kind of inputs on it. Sorry.
Yes that is exactly what you need sir but if memory serves me correctly on my last bike when I put the satellite in I had to use the SC-C1 module as well.
