Need install help!!!!
I have a 2012 Streetglide. I installed a Sony 310 BTX Head unit with a Biketronics kit, Polk MM651's and a SS 520 Amp. Got the HU and speakers installed with no problem. I installed the amp and turned the ignition on. The HU came on but the amp's power light did not come on. I rechecked all connections, radio and power wire fuse. Still no power. The amp is ground to the tripple tree. There seems to be no issues with my connections. Any advice? Is there something that I'm missing?
you need to make absolutely sure your ground wire is secure. Also did you install the fuse at the battery?
the sony blue/white wire is what's used to turn the amp off and on with the radio. there is also a blue wire that's used for power antennas that ONLY has power when in FM/AM mode.
With those terminal blocks on the side of the amp you also need to make sure that you've got the correct amount of wire stripped back from the end to insert into the necessary terminal.
do you have a test light or DMM? If so check that you have 12v from the ground on the triple tree to the + terminal on the power block of the amp.
Now, can someone tell me how they buttoned everything back up. I have all the wires ran out of the way. It seems as if my amp is preventing the front fairing from going back on.
The amp is pushed all the way back against the speedometer brackets, but it is still seems to be in the way. Has anyone had a problem with the SS 520 not fitting? Or did modifications have to be done on the speedo brackets to get it pushed back further?
man I've never had a problem especially with a street glide since there's so much more room inside the fairing to begin with and then with the replacing of the stock head unit gives you that much more room.
The only bikes I've had to cut the trim bezels on the back of the speedos was with the older 05 and back bikes.
Can you take and post a pic from the front so we can see what's going on please?
