can't click on links in pdfs in sticky section
ah I know what you're referring to.. Adobe for some reason removes my damn links inside the PDF files when I create them.
the first link is here
the 2nd link is several pics.
https://www.dropbox.com/s/8oz2s34hzje3plk/DSC00697.JPG
https://www.dropbox.com/s/ypebjjvjyhv0ddv/DSC00698.JPG
https://www.dropbox.com/s/5byxf5b6umt217u/DSC00699.JPG
https://www.dropbox.com/s/mxmhjtqekxmen8b/DSC00700.JPG
1 complaint....the 07 I read thru didnt mention the fuel crossover line...it does say to reference the manual at the top, but someone may get lost in the fun and not realize the pain in the a$$ crossover tube.
On a side note, does anyone have a good way to get that thing off without pouring a bunch of gas all over?
Personally I wouldn't remove the tank. I would simply take the two bolts out from the rear, loosen the two bolts in the front, lift the rear of the tank up and slide a wire hanger under the tank into the fairing to run my wires.
