Problem with rear speakers after SS amp install
Just finished installing new SS amp, rear pods and 4 Polk MM651's on a 2012 FLHTC. Fired it up with stock HU adjusted per Ultra's settings and gains set down. Sound from front speakers (Lots of sound!) but nothing from rears. Checked all connections. Still no sound. I tried increasing the gain but still nothing. I haven't been to dealers yet to have stock HU flashed because I thought that only turned on fader but outputs were still live to feed into amp. I did notice that when I was checking connections and touch the rear speaker INPUT, hear a hum come from the rear. Everything points to no output from 35 pin connector for rears. Am I missing something or do I have to have the dealer also turn on rear speakers?
Rear speakers are NOT live on 2006 & later FLHTC
I found this link to the Harley kit instructions for adding rear pods and speakers on an a 2006 & later FLHTC:
http://www.harley-davidson.com/en_US...ts/-J03653.pdf
The very beginning of the instructions state:
Additional Parts Required
NOTE
Even if this kit is not being installed by a Harley-Davidson
dealer, a speaker software flash must be performed on the
radio installed on the motorcycle at the dealer before the
speakers will function.
Looks like rear speaker feeds from radio are NOT live without the flash.
NOTE
Don't know exactly what was wrong but I suspect it was the connector to the rear amp input not seated correctly.
Can't thank the forum members enough for all their help and advice!
John
kingsrooke
06-25-2012 09:31 AM
