Rockford Fosgate PBR amps...good or bad buy?
Old 04-12-2013 | 05:44 PM
SweeetHemi's Avatar
SweeetHemi
Default Rockford Fosgate PBR amps...good or bad buy?
Does anyone have info or advice on the Rockford Fosgate PBR300X2 or PBR300X4 ?? I have a Street Glide and only need to power 2 batwing Hertz HCX 165's. Wondering if the RF brand is good and should I go with the 2 or 4 way?
Old 04-12-2013 | 05:54 PM
Pioneer74's Avatar
Pioneer74
Go with the PBR300x2.
Old 04-12-2013 | 05:59 PM
SweeetHemi's Avatar
SweeetHemi
Any reason why the 2 way and not the 4?
Old 04-12-2013 | 06:08 PM
Ride my Seesaw's Avatar
Ride my Seesaw
The 2 channel is rated minimum 100 watts rms per channel, the 4 channel amp is only 75 watts per channel. In addition the 4 channel amp will get much hotter trying to dissipate heat in almost the same surface area as a 2 channel amp. You are better off buying two 2 channel amps to run 4 speakers than trying to squeeze all that energy out of one 4 channel amp.
Old 04-12-2013 | 06:18 PM
jpit11's Avatar
jpit11
I have the 2 channel powering a set of Polk mm651's and it ROCKS. Check out the audio section. Lots if info and advice on these amps.
Old 04-12-2013 | 06:31 PM
0ldhippie's Avatar
0ldhippie
Lots of info on the 4 channels being crap. 2 channels are pretty good. Hot setup right now seems to be soundstream nano.
Old 04-12-2013 | 06:39 PM
Pioneer74's Avatar
Pioneer74
You're only using two channels and you can't bridge the PBR300x4.
floridapoolboy's Avatar
floridapoolboy
My 300x2 came with a bench rating of 193 watts per channel RMS into 2 ohms. Tough to beat that, and it won't make your FM stations go away!
Old 04-12-2013 | 07:14 PM
SweeetHemi's Avatar
SweeetHemi
Thanks everyone.
Sounds like good solid feedback on the RF PBR300X2....Never heard of the Soundstream Tarantula amps. But I do know RF has a pretty good name out there in the audio world.
Old 04-12-2013 | 08:44 PM
sawbones25's Avatar
sawbones25
RF PBR300x2 and Polk MM651's here also. No complaints. So much better than stock.
Quick Reply: Rockford Fosgate PBR amps...good or bad buy?
