My Road King Audio Setup
Updating post. Will add more details shortly - here are some pics from todays progress.
Fairing ready for installation
Bike ready for wiring installation.
Dead Center Quick Disconnect Harness
Harness used for Amplifier quick disconnect
Using marine rated, oxygen free, 10AWG power cabling from Metra Electronics.
Battery side harness completed
Dead Center harness and my 10AWG amp quick disconnect
Installing of radio cage
Bend tabs tightly to edge
Radio installed
Next was the Soundstream amp. This was a heck of a process. Wasnt sure the amp was going to fit but after a few hours of engineering this bracket I was able to get it in the fairing.
This was not the final rendition of the bracket but you can understand the concept.
Amp finally mounted with room for the fairing to seal.
New holes for the 10AWG power and ground for the amp, plus additional wiring pic
Radio installed
Wiring continued
Polk x-overs mounted with industrial velcro
Additional support for amp bracket
Installed poly-fil. Used the mounting hardware to keep in in place. I installed two layers.
Then I installed the protective ABS plastic that shields the equipment from moister. I didn't take a pic of that.
Finally I buttoned it all up, and back together.
Here's the fairing on the bike.
