ss amp and wiring Ultra nutz i need help
Old 03-31-2013, 04:42 PM
FatDadTwo's Avatar
FatDadTwo
FatDadTwo is offline
Default ss amp and wiring Ultra nutz i need help
Hi Guys
I bought the ss amp. What is the wires I need to hook it up.
What gauge power, ground Amp and speaker wire do you recomend
Old 03-31-2013, 05:04 PM
reesestewww's Avatar
reesestewww
reesestewww is offline
Originally Posted by FatDadTwo
Hi Guys
10ga power and ground will be fine IMO. As for your remote 18ga primary will suffice. Also 18ga speaker will be work, 16ga at the largest IMO.
Be sure to use a high strand count, no solid core.
UltraNutZ can validate. And for the record I'm not offended if I'm completely wrong.
Old 03-31-2013, 05:46 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
Hi Guys
what bike please?
2 or 4 speakers?
what model speakers?
stock head unit?
should be a forum requirement to list bike in signature line! :-)
Old 03-31-2013, 05:49 PM
UltraNutZ's Avatar
UltraNutZ
use your stock speaker wires. no need to change speaker wires with this setup.
Old 03-31-2013, 05:54 PM
reesestewww
Oh yea, I forget some bikes already have speaker wires
Old 03-31-2013, 07:51 PM
FatDadTwo's Avatar
FatDadTwo
I bought sony hu
ss amp
4 polk mm561
biktronis retro kit and sony plug
2007 electra glide classic with hog tunes rear pods. I took out the hogtunes and trying to drop in the 6.5 but they do not fit. I need to trim the pods.
Thanks for the advice. 1st time doing the install myself
I just ordered the boss 8 gauge amp install kit. Seems to have everything I need. Has any one used it.
what bike please?
2 or 4 speakers?
stock head unit?
Old 04-03-2013, 12:10 PM
NJShoreScott's Avatar
NJShoreScott
NJShoreScott is offline
UltraNutz, I have seen you say several times to use the stock speaker wires, and I can see doing that for the rears, but for the front, either I have to cut them similar to the rear, or I need speaker wire. 2010 FLHTK, Stock HU, HogTunes Speakers (for now), SS PN4.520D amp. Or am I missing something. It is the one piece of the puzzle that has me puzzled from your DropBox photo's and wiring diagram.
Old 04-03-2013, 12:13 PM
UltraNutZ's Avatar
UltraNutZ
you'll take your front speaker wires to go to the inputs of the amp directly off the fairing speakers so no cutting necessary other than snipping the connectors off the ends of the wires..
Old 04-03-2013, 12:21 PM
NJShoreScott
Makes sense, but I will need wire to go from the Amp outputs back to the front speakers. Right?
Old 04-03-2013, 12:22 PM
UltraNutZ's Avatar
UltraNutZ
yes sir
Quick Reply: ss amp and wiring Ultra nutz i need help
