Swap Soundstream Nano 4.520 for Rockford pbr300x2 ??
The FM interference I can't seem to eliminate has me on the fence.
I basically have 0 FM with the amp on. At low volumes I can pick a few stations up but as I turn up the volume it worsens until the point I have no tuneable FM. I have tried a different antenna plugged directly at the head unit.
This seems to be an issue isolated to a few cases. I can only figure it is something in the headunits because it doesn't appear to be an issue with any sony head units. I am just not sure I can live without FM radio.
The PBR3000x2 seems to not produce the interference.... I would use it to run my speakers in parallel to utilize a 2ohm load and get 150 watts per channel of 2 speakers.
ps...did you replace the pbr300x4 in your sig?
The amp is great. The speaker/amp combo work and sound killer. I have cranked it for some time and the amp barely gets luke warm. I have the gains at 30% frt 25% rear and it rocks.
The FM thing baffles me. I have 3 bikes now here that I have done using stock whip antennas with both stock and aftermarket radios and none have the FM issue. I do have 1 that does have the FM issue but is using an in-fairing antenna and the rear antenna is on a relocation bracket behind the saddlebag. There are some underlying issues with this and I'm trying to understand different setups to draw some kind of logical/technical conclusion for resolve.
Was it not you that posted that you connected your antenna wire directly to the antenna bypassing the antenna relocation bracket and 100% of FM reception came back? It may not be you just asking...
Wish I could get someone to try one of the +12v powered FM signal boosters to see if it helps. Something like .
