ipod on 03 electra glide
As Carl pointed out it's simply a swap out.
The only thing different is the newer radios use a digital signal for the AVC (automatic volume control) and the older radios like yours use an analog signal. If you want to retain the AVC, you'll need to send the newer radio to Iron Cross Audio and they'll convert the AVC signal input to analog to work with your specific bike.
motorups
11-07-2007 08:57 AM
motorups
11-05-2007 07:49 AM
