Hog Tunes Speakers or the Polks MM651s?
Ok, I know if the question was which to buy, it would be easy, the Polk MM651s. (And note to self, RTFBoard before purchase in the future). But I didn't and bought the front and rear Hog Tunes speakers a while ago. I am about to pull the trigger on the SoundStream 4.520 Nano amp, and am trying to decide if I should also get the Polks. I do not think there is a problem running the HogTunes with the amp (is there?)
So, will the speakers make a big difference? I am definitely NOT an audiophile, but I have noticed that Joe Cocker's "With a Little Help from my Friends" cuts out with my current setup (stock HU/HT drop in speakers - NO tweeter pod). I am sticking with just the four speakers (front & back), just want a little more volume at speed, and a little more clarity at volume. Stock HU is fine (for now), as the OL likes the intercom and even the CB.
I know this is a subjective question, and I generally hate people on this forum relying on others to make opinion decisions. But it seems like there are some very knowledgeable people on this particular board who can apply performance characteristics (and personal experience with the various components) to answer a bit more objectively.
Thank you in advance for any (and all) help.
i always recommend you use what you have first. If you need more later then do it. Why toss out perfectly good speakers IMO. The HT speakers are a good speaker and yes there are certainly better speakers. But better is directly proportionate to the way you like to listen to music and how much you want to spend in obtaining "better"
Try what you've got first man.. Then move from there if need be. The SS amp will wake those HT speakers up for sure and I think you just might like it.
It really shouldn't matter which brand or size speaker you're using.
Your gains controls on your amp are precisely for this.
So if you're running a 4 channel setup do this:
- Unplug your rear inputs to the amp (or use the fader to go to the front only)so you're only hearing your front speakers
- Set your bass and treble on your radio to flat (that would be the middle on stock radios)
- set your gains on your amp both front and rear to min (usually all the way to the left)
- turn your radio up until you start to hear distortion then back it off a tad bit.
- now turn your FRONT gain up until you start to hear distortion then back it off a tad bit.
- fade your radio to the rear or unplug your front inputs to the amp and plug your rear inputs back in so you're ONLY hearing the rear speakers.
- follow the steps above to set your rear gains.
- fade back to the middle or plug your front inputs back in
- now you're set both front and rear.
