Road Glide Audio Upgrades
Old 05-06-2013, 06:29 PM
Beachman139's Avatar
Beachman139
Beachman139 is offline
2nd Gear
Default radio
ill call am and ask them if they know its a 12v powered anteena, im sure they dont
  #32
Old 05-06-2013, 06:30 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
the fuse, if it's powered may or may not affect reception. pretty much anything that's plugged into the antenna port is going to be able to pick up strong stations, it's the weaker stations that it won't do so well with when the antenna is working properly and therefore much worse when it's not working right.
  #33
Old 05-06-2013, 06:36 PM
Beachman139
2nd Gear
Default radio
going back to harley next monday, looks like will pull the radio and send it out to be checked,
  #34
Old 02-05-2014, 02:06 PM
BigMike43's Avatar
BigMike43
BigMike43 is offline
That is one badass system well worth thr money!
Originally Posted by LDIReproPhil
Exceeds expectations. Mic on ipad couldn't handle the volume which is why you hear that high pitch scratching sound. More bass and crystal clear in person. Probably will sound even better with a higher quality song file.
http://www.youtube.com/watch?v=tdxs2ALKgUk
  #35
Old 02-06-2014, 08:12 AM
UltraNutZ's Avatar
UltraNutZ
No kidding. Sounds great
  #36
Old 06-14-2016, 12:32 PM
naamang's Avatar
naamang
naamang is offline
Stage III
Default Tweeter adapters?
Where did you get the tweeter-to-gaugehole adapter mounts? I don't see them being sold with the HSK-165XL speaker kit...
  #37
Old 06-14-2016, 01:36 PM
UltraNutZ's Avatar
UltraNutZ
you can either use something like a hogtunes or hawg wired tweeter which pops right in without the need for an adapter or you can grab you a set of gauge hole plugs from HD which is what they use on the electra glide standards. Drill them out to size and they snap right in then your tweeter snaps right into them.
Harley part # 75106-96A
  #38
Old 06-14-2016, 01:53 PM
LDIReproPhil's Avatar
LDIReproPhil
LDIReproPhil is offline
I have a CVO so stock speakers were there in those holes. Easy swap for me! 👍🏽
kidsid99
Audio Systems
06-09-2018 02:42 PM
Danow777
Audio Systems
03-07-2014 02:41 PM
BrianCash
Audio Systems
02-16-2014 07:07 PM
zeus33
12-18-2011 08:05 PM
Quick Reply: Road Glide Audio Upgrades
