Road Glide Audio Upgrades
Radio
Hey , I have a 2013 cvo 110 anniversary road glide, I have terrible static In most areas, I'm in , in NYC or elsewhere with fm stations, when I tested the radio in the show room in NJ I thought it was awesome , since then it has been all downhill, cd, and iPod plays great, I do have a internal antenna but don't know if that is the issue, I did put a set. Of sumax 8 mm ignition wires, and led turn signals in front , had to get a load equalizer , for lights ,can anyone give me some help with this , I personally thing there something wrong with the radio, I plugged in the factory wires again to see if there was a difference, but didn't see that, and I don't think the LEDs would have something to do with it, and also sometimes I can't change the station from the hand control or by pressing button next to station , but then all of a sudden it works , so it s driving me nuts I need some advice, by the way , I took it back to Harley took off fairing to see if antenna was intact , and it was, so there telling me its the internal antenna, can't be cause it worked fine when I first checked it out in the showroom
have you verified that you have the latest firmware/software installed on the radio?
http://www.harley-davidson.com/en_US...io-system.html
in fairing antennas are the worst for reception, period. The question is whether or not it's a 12v powered antenna and if so, has someone checked to see if the fuse for it is blown.
